Plastic Diamond Plate
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
Anyone have any idea where I can buy some black plastic diamond plate?![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
I want to use it to cover up the screws/holes I put in my doors when adding an aftermarket power lock kit.
Everything I found on ebay.. is like sticker type plastic.
I was looking for something a little thicker that I could mount on the door with some screws, that way I could remove it later on if I need to.
Also, looking for plastic sheeting, that the diamond plate is actually textured into the plastic.
Thanks for the info though!
Yo might have better luck searching for PVC diamond plate or polypropylene diamond plate. Plastic is not a word used by many manufactures since it is so generic.
I was hoping I could find some that sorta matches the diamond plate plastic that is part of the door panel.
Plus it's a lot easier for me to manipulate.
Try tuffy, I now they make something for the tops of there security boxes.![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
http://www.tuffyproducts.com/p-218-8...ate-vinyl.aspx
plasticsmag.com/ta.asp?aid=4087
TRY THIS...
OR THIS
kenmarkinc.com/gallery/showimage.php?i=243&catid=popimages
TRY THIS...
OR THIS
