Planning on regearing? You may want to read
Old 03-26-2014, 06:34 PM
  #231
Forum Tech Advisor
planman's Avatar
Originally Posted by jkfletch7
I'm not sure if anybody said this but there is a simple formula to get the gearing that you want... ((Tire size you have)x(stock gear ratio you want to match)) / (stock tire size) = gear ratio you want Also you want to round up to the nearest gear size to offset the increased weight
The problem with that is that 07-11 automatics should have come with 4.56s or 4.88s to match the engine rpm and performance of the 07-11 6 speeds.
The big advantage of the '12+s is less the engine and more the transmisson ratios. The transmission 5th/OD gear and 6th gear ratios are lower than 07-11 automatics and 6 speeds, requiring less differential gearing.
The 3.8L engine works fine if your differential gearing is low enough to run 2500-3000 rpm at 70 mph.
Old 03-27-2014, 07:26 AM
  #232
jkfletch7's Avatar
Originally Posted by planman
The problem with that is that 07-11 automatics should have come with 4.56s or 4.88s to match the engine rpm and performance of the 07-11 6 speeds. The big advantage of the '12+s is less the engine and more the transmisson ratios. The transmission 5th/OD gear and 6th gear ratios are lower than 07-11 automatics and 6 speeds, requiring less differential gearing. The 3.8L engine works fine if your differential gearing is low enough to run 2500-3000 rpm at 70 mph.
I completely agree but then if you want to match what the jeep would be stock with higher gears (numerically) you could just plug those gears into the (stock gearing you want to match) part of the formula
Old 03-27-2014, 03:09 PM
  #233
KMM
KMM's Avatar
Anyone with an auto 09 X have any recommendations for running 35s on a daily driver, mostly highways, and a few wheeling trips a year?
Old 03-27-2014, 03:20 PM
  #234
TJM12's Avatar
5:13 -5:38 for the 07-11 autos on 35's
Old 03-27-2014, 03:27 PM
  #235
Todd2291's Avatar
I went with 5.13's with my auto 09 x
Old 03-27-2014, 03:56 PM
  #236
CerOf's Avatar
Doesn't work or translate. We are not conducting tests in a vacuum.
What you say is the equivalent of the question, "Which falls faster? A feather or a brick?"
35" tire is more than just height/size. It is rolling resistance, wind resistance of the tire itself. Increased ride height creating more wind resistance of the Jeep itself.
Sent from some string and a few tin cans.
Old 03-27-2014, 05:14 PM
  #237
jkfletch7's Avatar
Thank you for your opinion but I disagree, it works very well in my opinion
Old 03-27-2014, 05:28 PM
  #238
cctroupe11's Avatar
I run 4.88's in my 2012 w/ 5 spd auto, 37" trail grapplers. I tach about 2300-ish at 60mph in 5th gear. I'm pretty happy with that ratio.
Old 03-27-2014, 05:32 PM
  #239
pjmjk's Avatar
Anyone have opinions on a 2010 3.8 manual with 37 inch Toyo MTs. Mostly daily driver with mix of city and highway driving at most 45 min trip. It has 3.73s right now I'm not sure how far I want to go to reestablish full power and good 70mph highway rates.
Old 03-27-2014, 07:14 PM
  #240
KMM
KMM's Avatar
Do you guys like the 5.13? How is it on the highway? I commute about 80 miles a day and I'd say 60 mi is highway.
Quick Reply: Planning on regearing? You may want to read
