Planning on regearing? You may want to read
Old 05-27-2012, 02:51 PM
  #131
JeepBerg's Avatar
Originally Posted by Vladivar
So my situation right now is a 2010 2dr Sahara with a 6 speed and 3.73 gears (went with the factory tow package). With this combo I am at about 2150 rpm's at 65 mph in 6th. My plan is to go with a 2.5 inch lift and 33's. Most of the comments so far are around having to re-gear when going to 35's. If I only go to 33's, will the stock 3.73 gears work ok?
Thanks.
Drive it that way and if you don't like it, then re-gear.
Old 05-27-2012, 04:28 PM
  #132
Wgrin's Avatar
Originally Posted by nucknphuts
I have a '11 2dr sport with 3.21's, dana 30 on the front and dana 44 on the back. If I wanted to go up to 3.73 would I have to change out the carriers as well or would the originals work?
I can tell you that you won't notice much of anything doing such a small gear change. At least go to 4.10 or better yet goto like carmax and test drive an 11' rubicon with 4.10 or even the 3.73 and see how you like it
Old 05-28-2012, 06:38 AM
  #133
JPop's Avatar
Yes you would need a new carrier. Probably advisable to go with something beyond 3.73s depending on your tire size. Even 3.73s are a 15+% steeper gear set than your current 3.21s, but if you plan on rolling 35s you probably want to look beyond 3.73s.
Old 05-28-2012, 07:48 AM
  #134
Stuka's Avatar
You do not need a new carrier to go from 3.21 to 3.73. 3.73 is the carrier break. He would only need a carrier for 3.92 and lower (higher numerically) gears. Although 3.92's are not made for JK's, next step is 4.10's.
Old 05-28-2012, 08:02 AM
  #135
JPop's Avatar
I could be mistaken although as far as I know the D30 has a one carrier for 3.21s and another for 3.73 and up. The rear carrier is the one that wouldn't need replaced.
Old 05-28-2012, 08:37 AM
  #136
JeepBerg's Avatar
I have 3.73s in my '11 Sahara and was planning on going to 5.13s when I switch over to '37s. I've seen kits on quadratic.com that say nothing about needing a new carrier.
Old 05-28-2012, 08:46 AM
  #137
Stuka's Avatar
You are right, just looked it up. The D30 is 2.73-3.54, and then 3.73-5.13. Just about every other axle out there is 3.73. So my mistake. You do need a carrier for going to 3.73's.
Old 05-28-2012, 08:52 AM
  #138
JeepBerg's Avatar
Go with a G2 to save a little $ and get a complete package or if you want to order separate pieces and money isn't an issue, Dynatrac 44 front. That's what I want.
Old 05-29-2012, 05:59 AM
  #139
dellpjJK's Avatar
This appears as if you don't have your speedometer calibrated. Without calibration you could be rolling as much as 5mph faster than your speedometer indicates. Stock tires, 4.56s and 70mph would place you where you indicated although you are currently running 33s. Best to get a Procal to get things in line or one of the many tuners available to get a power bump as well as some additional performance.
I checked speed with GPS. I'm going about 1MPH faster than what it reads at 70mph which I had taken into account. Yes, I'm on 33's, or the metric version for 33's.
Old 05-29-2012, 06:04 AM
  #140
Poser's Avatar
Had 3.21 in my '10 and upgraded to 4.88. Am I missing something here?
Quick Reply: Planning on regearing? You may want to read
