Planning on regearing? You may want to read
#121
As you mentioned towing, 4.10s for 33s and 4.56s for 35s. You really want to get into the torque band higher when you're pulling some weight, and minimize your downshifts.
#122
Where did you find this chart?? Is there one for the 2012 JK's with the 3.6??
#123
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/#post211276
#124
456
So got my gears done today and wow its a whole new world. I should have done this when i first bought it.
I did 4.56's and now in 6th I'm running about 2950 rpms at 70mph. This is a bit higher than what I wanted, but I'm installing 35's, so expect that to go down a few hundred rpms, and be just about perfect.
#125
#126
#127
Originally Posted by TJM12
Wow that rpm range seems a bit high for 70mph and 6th gear? Is this with stock tires and rims? What size tires do you have?
And here is something people should consider. 6th gear should be an overdrive, so just for cruising. If you can climb any gear in 6th gear, then you are geared too low IMHO.
#128
Trying to get a handle on this
So my situation right now is a 2010 2dr Sahara with a 6 speed and 3.73 gears (went with the factory tow package). With this combo I am at about 2150 rpm's at 65 mph in 6th. My plan is to go with a 2.5 inch lift and 33's. Most of the comments so far are around having to re-gear when going to 35's. If I only go to 33's, will the stock 3.73 gears work ok?
Thanks.
Thanks.
#129
Thanks.
Thanks.
#130
