Planning on regearing? You may want to read
Old 05-21-2012, 02:48 AM
  #121
JPop's Avatar
Originally Posted by Makeitwork
Would I have to sacrifice one of the other to get exactly what I'm looking for, in terms of acceleration and towing power and fuel economy. or is there a way to obtain a bit of both..
As you mentioned towing, 4.10s for 33s and 4.56s for 35s. You really want to get into the torque band higher when you're pulling some weight, and minimize your downshifts.
Old 05-23-2012, 09:16 AM
  #122
JKLarson's Avatar
Originally Posted by Alias
I always prefered this chart, as it breaks it down for manuals and auto's. For my uses and since i drive a manual i think 4:56 is the way to go, but yes like you the shop keeps insisting i put in 5:13's
Where did you find this chart?? Is there one for the 2012 JK's with the 3.6??
Old 05-23-2012, 10:06 AM
  #123
JPop's Avatar
The chart for the 2012s is in the FAQ.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/#post211276
Old 05-25-2012, 07:05 AM
  #124
dellpjJK's Avatar
Default 456
So got my gears done today and wow its a whole new world. I should have done this when i first bought it.
I did 4.56's and now in 6th I'm running about 2950 rpms at 70mph. This is a bit higher than what I wanted, but I'm installing 35's, so expect that to go down a few hundred rpms, and be just about perfect.
Old 05-26-2012, 02:01 PM
  #125
Wgrin's Avatar
I kind of wish there was a way to like test drive all the different gear ratios just to see how they all feel.
Old 05-26-2012, 02:11 PM
  #126
TJM12's Avatar
Wow that rpm range seems a bit high for 70mph and 6th gear? Is this with stock tires and rims? What size tires do you have?
Old 05-27-2012, 08:28 AM
  #127
Stuka's Avatar
He currently has 33's as I recall.
And here is something people should consider. 6th gear should be an overdrive, so just for cruising. If you can climb any gear in 6th gear, then you are geared too low IMHO.
Old 05-27-2012, 08:31 AM
  #128
Vladivar's Avatar
Default Trying to get a handle on this
So my situation right now is a 2010 2dr Sahara with a 6 speed and 3.73 gears (went with the factory tow package). With this combo I am at about 2150 rpm's at 65 mph in 6th. My plan is to go with a 2.5 inch lift and 33's. Most of the comments so far are around having to re-gear when going to 35's. If I only go to 33's, will the stock 3.73 gears work ok?
Thanks.
Old 05-27-2012, 08:58 AM
  #129
Stuka's Avatar
Thanks.
I think you will be fine. Going from 32 to 33 inch tires is not a big jump. And 3.73's are already pretty decent.
Old 05-27-2012, 09:27 AM
  #130
JPop's Avatar
This appears as if you don't have your speedometer calibrated. Without calibration you could be rolling as much as 5mph faster than your speedometer indicates. Stock tires, 4.56s and 70mph would place you where you indicated although you are currently running 33s. Best to get a Procal to get things in line or one of the many tuners available to get a power bump as well as some additional performance.
Quick Reply: Planning on regearing? You may want to read
