Pitman Arm Puller and Steering Linage Puller
The Rancho lift kit that I am going to purchase for my 2008 JK Unlimited recommends the following pullers:
Pitman Arm Puller C-4150-A
Steering Linkage Puller C-3894-A
Does anyone know where can I buy these or equivalents?
Thanks!
Thanks!
Pitman arm pullers can be bought at most auto parts stores, or rented from Autozone, if you have those in your area. I'm not sure what they meant by a steering linkage puller, but it is probably the same as a tie rod end puller, which is also available at the auto parts store. Both look the same, but the pitman arm puller is larger. Good luck.
