Pitman arm bolt loose
A pipe wrench and hammer? Just kidding. Removing the track bar is easy. There isn't any short cuts to do the job correctly. If you try to take short cuts, you wind up on the forum asking how to get to bolts to torque them. Hah.
Sent from the fast lane while driving one handed.
The pits
Not only the track bar. You may also want to drop the drag link. Get a 4' pipe to fit over the pitman arm to use as hold-back while you torque the nut to 185 ft-lbs. Why risk damaging your steering box?
Just a thought. Void where prohibited. Your mileage may vary.
