Pintlers are a go - what size tire??
I've searched quite a bit and haven't found anything that concretely answers my question. Can anyone definitively tell me what size tires (.../.../...) to run on a set of AEV Pintlers? I've seen about a hundred suggestions. They are going on a stock '12 Sahara JKU. I'm looking for 33's with some width but without any rubbing. I'm open to removing the air dam if needed. I'm looking at Duratracs, KM2's or Trail Grapplers. No plans for a lift but maybe a leveling kit if needed. It's a DD with minor offroad use planned. Pics would be appreciated. Thanks in advance for help with the rookie question.
Height is easy to answer, go as big as you can afford to run. Sure you can do 33' on stock suspension and feel good about it, for a week or two.... Then you are going to start lusting after 35" or 37", sooner or later you will break down and buy a whole new set of tires.....
If you have NO plans to add a lift in the next year, i'd say go with 35's and some flat fenders. Bushwhackers at $600 for a full set is a good approach. Now you'll fill the wheel wells and be ready for a lift down the road.
Just remember, every dollar you spend is going to lead to 10 more dollars you'll need to spend....
Good luck, its always hard to make the best choice the first time around
Thanks for the responses so far. I'm planning to stick with 33's as anything higher would be tough for my girl to get into. Specifically, what dimensions should I be looking at for tires?
