Pinch Seam Questions
Old 07-02-2011, 03:40 PM
JKZinger's Avatar
Default Pinch Seam Questions
Anyone have any good pictures on how they modified their pinch seam and Rubi rails to fit 35s? What did everyone use to cut them?
Old 07-02-2011, 03:50 PM
dillUSMC's Avatar
i used a grinder to just cut it diagnoly so it was nowhere near the tire then sprayed it with some rubberized bedliner,
Old 07-02-2011, 04:17 PM
boboborino's Avatar
apparently it is not necessary to cut your pinch seem to fit 35's, I thought it was when I cut mine, but I am glad I did it anyway, much cleaner look and oh ya, it was fun
as far as pics and info on doing it just search and you should find it, there are two ways of doing it, cutting it and the other way is to take a big effen hammer (BFH) to it. I used a sawzall( reciprocating saw)
Old 07-02-2011, 04:38 PM
Sierra141's Avatar
I dint have to cut, I guess I got lucky The Rockrawler lift moves your axle back in order to avoid rub ::beers:::
Old 07-02-2011, 04:58 PM
kb1
kb1's Avatar
Search for Planman. He did a thread on it when he put on 37's. Really nice write up.
genesbro's Avatar
Mine don't rub either, you can actually see that the axle has move back slightly with the new control arms that were installed with the lift.
Old 07-02-2011, 05:02 PM
Grisha's Avatar
Sawzall + 10 seconds
Old 07-02-2011, 05:34 PM
archijeff's Avatar
I used grinder for my 37's but didn't need to with 5" lift.. Cleaned it, primed it, and painted it.. My axle moved forward because I wanted my pumpkin at correct angle of ds
Old 07-02-2011, 05:39 PM
dillUSMC's Avatar
yea with some lifts and tire combos you dont have to but its cheap insurance on protecting 1000+ dollars of tires
Old 07-02-2011, 08:16 PM
JKZinger's Avatar
Thanks to all for the info!
Quick Reply: Pinch Seam Questions
