Pic request of OME lift on 2 door
Old 04-09-2008, 06:59 AM
JeepDog's Avatar
Originally Posted by hiteck
How long did the install take? I've seen anywhere from 2 - 8 hours...lol. Also did you install adj track bars?
Took us 2.5 hours. Thats including the adj. Trackbars. Make the trackbars 1/4" longer then the factory ones (per Dave) and they were dead on.
Watch the rear brake lines they get tight. I removed them from the mounting bracket to install the springs and then mounted them back up. There IS enough room just not enough to get the springs in. Hence the removal.
Oh I didn't notice but if you have a rubi, watch the cable on the front end housing. it has a plastic push holder pin that fastens it to the diff. Its gets VERY tight...I pulled this out to get the front axle to drop far enough. Then put it back when I was done.
Old 04-10-2008, 08:25 AM
hiteck's Avatar
Thanks JeepDog for the reply and the info on the 1/4" longer tip.
Hopefully I wont run into to many problems tomorrow evening and will be able to get it done in 3 hrs or less.
Old 04-10-2008, 09:55 AM
zeeksta's Avatar
heres mine no spacers
Old 04-10-2008, 10:07 AM
hiteck's Avatar
Thanks for the pic, Did you go with the HD springs? What size tires?
Old 04-14-2008, 07:14 PM
hiteck's Avatar
Finally got my done and figured I'd add to the thread for future users
Old 04-15-2008, 03:49 AM
CrunchyOatmeal's Avatar
Got my OME HD kit yesterday. Installed the front springs and shocks last night and then ran out of daylight so we had to stop. Will install the rear springs and shocks today and post some pics this afternoon.
derekls's Avatar
Here is the Light springs front and rear on 265/75/16s ... I think I need bigger tires
Old 04-15-2008, 05:42 PM
Finished the install of my OME HD today. I love it. Full traction adjustable track bars get installed tomorrow. I am running Toyo OC M/T 35x12.50 r17.
Old 04-15-2008, 06:08 PM
chucktuna's Avatar
Green looks good!
Nice set up....
chuck
Old 04-15-2008, 07:10 PM
ChewyGranola's Avatar
Good job dude.
Quick Reply: Pic request of OME lift on 2 door
