Pic request for 2.5" lift with 34" tires
#31
#34
Sorry if this question is dumb I'm trying to get a better understanding of how back spacing works... If wheels had 4.5" back spacing instead of 4.75 would they still rub... Also if I don't have a lift will 28/75/17 fit with right wheels thanks for the help
#36
I ran that for a couple of months and then I added the bds 3" lift
Matthew
#38
#39
Location: Hawai'i, Miami , FL, Alaska, Tennesse..S America
#40
No problem. Took me a bit to get my head wrapped around BS as well. The stock JK has a BS of around 6.25" I believe. When you lessen the back spacing basically the tire sits out past the fender and is less likely to rub. 4.5" of BS is ideal you will not rub nor will 4.75. I don't have 285's so I am not certain if they can be run on stock wheels without rubbing but I can't see why not. Try test fitting one and seeing first. But if you have 4.5" of BS you will be good to go.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=494621"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=494626"/>
