Perfect Rear 44???
Perfect Rear 44???
I have been looking around and found many ways in which guys have upgraded their rear D44.
Some like to keep the rear open with stock shafts and just replace them as they go, some like open with upgraded 30spline shafts, some like locker with stock shafts, others like locker and upgraded shafts....some have thrown on a truss for good measure.....
With all that said, what would you guys do with a stock sport rear D44 in order to make is a good as possible with the best functionality.
Reason I ask, I have decided t forgo my rear coil overs and address my rear D44. If that means that u should just buy some additional rear shafts to take with neon the trail, kinda wanna know what yall think.
We have some loose dirt here in my portion of Texas and so nice rocky areas too. Not much in the mud.
Thanks door y'all's help!!!
I was anticipating these to have the same basic flanges as the stock d44 but with just a larger diameter hear setup?
I wouldn't put a bunch of money it personally. Chromoly shafts and maybe a truss. You might find a used Rubi rear 44, and wire up the locker, and do the above mods. Should hold up for 37's, at least for a while.
I regeared to 5.13 and left open, then to 5.38 and added air lockers. Then the rear flanges bent, so upgraded to alloy. Tubes spun a bit, so had them welded up. Wish that ultimate 60 had been out way back when...
