People who have 37s does ur jeep drive stright???
Running different psi will wear your tires different but you should never be able to notice. If you are 5 tire rotating it should even out. Additional caster on the passenger side, longer lower lca, will not effect your tires but should ease that pull to the right.
sent from my work leash
Forum Tech Advisor
If you have 37" Toyos, they will wear a little funny anyway. They are designed for lifted full-size diesel trucks that tow very heavy loads. You'd probably have to run them at less than 26 psi to get a flat treadwear pattern anyway. At lower pressure, you'd start cold days with flat spots until the tires warm up.
Just rotate the tires at every other oil change interval and you should be fine.
I've Had my Nitto Trail Grappler M/Ts on for 3 weeks now. Mine drives straight as an arrow. It will wander a little under hard braking, but not in the same direction every time.
Sorry try this https://www.jk-forum.com/forums/modi...tuions-287457/
Lol my 37s sadly pull towards muddy ditches of doom in a suburban area lmao I think it's frowned a upon in today's society to drive threw people's front lawn!!!!!!!
