Penastar Engine Swap
#21
I understand. Guess then I would just chip it and gear it (and maybe RIPP it) to get the most performance I could from the 3.8.....and enjoy it!
#23
Chrysler isn't spreading lies, Ripp is using a 2012 Rubicon(4.10s) with the new automatic(Over 30% power loss) that isn't even broken in. You have to keep in mind that WHP and HP are two totally different things. HP is measured at the crank and with the penni it is rated at 290hp. WHP is measured at the wheel with the vehicle in the gear closest to a 1:1 ratio. The dyno also doesn't allow for the acceleration performance gain due to the addition of another forward gear and Ripp fails to mention the manual transmission only looses around 20%. If you look at the 3.8l performance charts from Ripp you will notice that it doesn't make anywhere near 205hp at the wheelsl. We will get a better idea of the pentastar's performance after Ripp hits that 5000 mile mark on the odometer when the VVT kicks in.
#24
Is the VVT even electronically controlled? Please show us where you got your info from.
#25
1 Post
See. This is why I didn't pour thousands (or even hundreds) of dollars into modifications on my 07' JK. The time and money people wasted trying to make their JK's more enjoyable they could have saved and put towards a 12' JK. It's not like news of a Pentastar upgrade wasn't already out there in the mainstream a couple years ago.
You swap out a 3.8L for anything and you're going to come out of pocket pretty heavily. And your JK is going to spend more time in the garage than on the trail.
It's a waste of time to consider swapping out a 3.8L with anything prior to 2007 (damn I6 lovers). A Hemi is not going to significantly outperform a Pentastar to the point where you'll be left in the dust holding your pride. Again, a waste of time and money unless you just have loads of cash to burn and want a Hemi just for the hell of it, which means you shouldn't be whinning about buying a 12' anyway.
To get the kind of reliable, consistent performance you'd get with a Pentastar you'd have to make significant upgrades to whatever engine set-up you decide to go with, which means you'll be wasting more money. All this nonsense about re-gearing and trying to find the biggest ass mud bog tires you can find is also a waste of time. You will also be sitting in your garage whinning about various parts you've broken and how to get the right set-up for gearing and tires.
If you really want affordable, beastly performance out of a Jeep, then buy yourself a CJ that's already been built right and use your JK for a daily driver. You'll come out cheaper if you're really that afraid to part ways with your old JK and that afraid to pony up and buy yourself a 12'.
#26
The only dyno that really matters is the butt dyno.
If the 3.6 only puts down 180 at the wheels then the 3.8 put down 90. Butt dyno doesn't lie
chassis Dyno results are so bogus anyways, they are used for tuning.
One brand of dyno measured my bone stock mustang at 268 at the wheels, the other brand dyno said 240...no changes.
#27
I know the VVT is electronically controlled, however I can't prove the 5000mile rule. That is just what I've always heard here at the dealership. I have never seen it in writing. I can however prove that the computer is in limp mode until 300 miles. It is set like that to allow for proper break in time of other powertrain components. Ripp dynoed their Jeep the moment they got it, and I doubt it even had 100 miles on it. Like I said, I just want to see some dyno charts after the motor has had time to get settled. 5000 miles sounds like a really nice number(VVT or not).
#29
(no long block yet)
Short Block:$1335.00
Right Head:$397.00
Left Head:$470.00
Head Set:$61.60
Total:$2,263.60(not including brackets, accesories, intake, oilpan, harmonic balancer, belt, etc.
