pcs hood louver
Old 12-07-2013, 10:20 AM
jkkrawler's Avatar
Default pcs hood louver
So my amazing gf gave me my Xmas present early. A Poison Spyder hood louver. I plan on doing it myself and just asking if there are any tips on how to do it. Or anything I gotta watch out for.
Old 12-07-2013, 10:23 AM
stagedtrip's Avatar
The hardware breaks easliy so be careful when tightening them down. Other than that just follow the template and go slow and easy
Old 12-07-2013, 03:02 PM
BIGNICK's Avatar
Watch when you tighten the bolts you could dimple the hood and if using a cutting wheel cover up everything I did everything but the windshield and the sparks etch'd it
Old 12-07-2013, 03:19 PM
JE8154's Avatar
Mask off everything, cover the windshield, put a drop cloth under the hood if you're not going to remove it from the jeep. Touch up paint on everything you cut. What are you planning on cutting with?
Old 12-07-2013, 03:25 PM
Papawhiskey's Avatar
You definitely want to take off the hood. cover everything that's not going to be cut. Paint all the cut edges with some rust proof paint. I used a pnuematic high speed cut off tool. It cut through the sheet metal like butter.
Old 12-07-2013, 03:58 PM
mOjO_JK's Avatar
hey everyone....I'm in the process of installing this right now...I ordered it bare steel and I am using herculiner...I did prep it with self etching primer....so far I did the top piece of the lovour...but now I'm thinking do I have to herculiner the underneath part?:..it's not gonna be showing? but will the heat from the engine do anything to primer? assuming I applied it "correctly"...feedback please
Old 12-07-2013, 04:14 PM
stagedtrip's Avatar
Yeah do the bottom
Old 12-07-2013, 04:26 PM
mOjO_JK's Avatar
might as well huh?
Old 12-07-2013, 04:33 PM
Billbikes's Avatar
I don't know if I'd Herculune the bottom, but I'd at least paint it with a good rust resistant paint.
Old 12-07-2013, 04:38 PM
mOjO_JK's Avatar
well that's why I did...I used self etching primer...followed the directions as labeled...it's covered...but besides the rust...shoudlnt be any problems if I don't herculiner it?
Quick Reply: pcs hood louver
