Patching a hard top?
So I hit a tree and cracked my hard top. Seems to be mostly cosmetic. Black is broke off and some fiberglass is showing. Any suggestions on how to patch it. I live in an area that has harsh winters and I am affraid if the fibers get wet then freeze it will crack worse.
Field Repair
Can you post a picture of the damage? Auto body supply shops sell repair kits for damaged fiberglass/ plastic/ SMC materials. You might be able to "V" out the cracked area, and apply an epoxy adhesive for strength, and a filler for the cosmetic part..
Just make certain that whatever repair is applied is compatible with SMC, not just regular fiberglas. Your top is SMC.
BTW: I bumped a tree while descending a steep hill at Disney, OK a few years ago. I've just started keeping my hardtop on longer, so have similar worries as you about a severe winter storm working the cracks open. I will probably just pay a pro to do the repair work.
Anthony Fernandez (10-23-2019)
Use gflex 650 epoxy resin ! Works like a charm . Great for cracks and huge holes . I put my SUT top back together with stuff .... No fiberglass or cloth needed !
