Passenger side lean - how much?
I know this has been talked about before and that it appear normal to have that right lean due to gas tank. But how much are we talking about?
What seems excessive?
I have a TF leveling kit w/ 1/2" front spring spacers. Also now have a Rock Hard bumper with tube extensions.
Springs are seated and everything is torques after setting on the ground, I now have a 1/2" to 3/4" lean in front, about 1/4" in the back.
Are Teraflex coils side specific? I don't believe they are.
It's not really obvious from the front unless you know to look, and even then you can fool yourself into seeing it or not seeing it.
It's much more obvious when you stand back and look at the drivers side wheel dwell and then immediately go and look at the passenger side.
I suppose I am being too picky, but this is my first do-it-yourself job so I am extra sensitive.
I suspect the heavy bumper magnified the difference.
Has anyone added a second or thicker coil spacer to the front and/or rear passenger side to level it out side to side? Something about that messes with my sense of symmetry, much like having the d30 up front bugs me.
In fact, when I weighed it with four scales, each right scale read the same as the corresponding left scale.
