passenger front tire is cupping
not sure why but the tire is cupping and starting to have slight vibrations in the steering wheel due to the lugs being higher and lower throughout the tire's diameter.(i assume)
My alignment is perfect......no braking issues.
any suggestions on why only 1 tire would be experiencing this.
mods are:
2.5" RC spacer lift
stock sport shocks
35" x 12.5" tires
mods are:
2.5" RC spacer lift
stock sport shocks
35" x 12.5" tires
Improper air pressure? Is the cupping in the center of the tread? Too much air will wear the center faster, too little wears the outside. It could be a bad tire but inside or outside edge wear would indicate a camber issue. Bad ball joints or bent C would take it off camber.
It's wearing on the center lugs... Every other lug is the one affected all the way around the tire..
I've seen cupping before but never so perfect on every other lug
i installed a 1.5" Teraflex leveling kit on mine and then went on a 4000 miles Jeep Trip and noticed on the trip that both my front tires were starting to cup. I've had motorcycle tires do it but never a vehicle. I plan to go get mine balanced and aligned. I might have knocked a weight off while off roading. Also got to check the air. Too little air made it worse on the motorcycles. When I roll to a stop at a stop sign, I can feel every lug as it rolls.
Was that pressure taken when tires were cold? or after driving for some time? I ask cause I'm having the same issue but both from tires. Shocks are new from RC with the lift. I have 35psi when i start in the morning, but by the time i get to work, its about 39-40psi.
