P0733, incorrect 3rd gear ratio?! 08 auto jk
3rd and 4th gears are not working
Garage telling me hall trans should be changed
Is it possible to be the valve body accumulator plate ? Anyone faced same issue ?
http://www.offroadpowerproducts.com/...2-jeep-jk.aspx
And anyone had experience w/ this trans offered by this site ?
I have prodigy turbo and i think i need stronger trans and going into manual will be headache for me
Sounds like the transmission went into limp mode.
Were any other codes present? Maybe P0870 and/or P0871?
What troubleshooting did the shop do to come to the conclusion the transmission needs replacing?
You problem could be as simple as a bad sensor.
With the turbo, and operating in the sand, you are correct in thinking you need a stronger transmission, though.
I don't know how exactly the shop reached to this conclusion. I dropped the jeep to the shop on wednesday and we have weekend on thursday and friday, they should open on saturday so i will go and make sure
The jeep just gave me this code p0733
I am running diablo in-tune which comes with the turbo kit
