Overheating
Overheating
So I have a 2012 Unlimited Sport and recently I've been having a couple problems with it. First I've been hearing a sound of water rushing from under the dash on the passenger side. Then recently the jeeps been overheating to about the 3/4 mark on the temperature gauge when I drive it usually on the freeway. Tried doing a flush and fill then changed the radiator cap and also the thermostat and all those symptoms are still present. Wondering if any of you have had similar issues and/ or any ideas on what the problem is/ how to fix it.
If you filled it up and purged the system then you should not hear any noise. If you are hearing noise then your water is going somewhere. There could be several different reasons for losing water. Find out where it is going and you will fix your problem.
