Out of the country and i need help!
Old 11-09-2012, 11:21 AM
emtclimbermatt's Avatar
Originally Posted by Delux2769
Here's what I just took pictures of:
Here's the top opening overalls:
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=387069"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=387071"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=387074"/>
Here's the very bottom:
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=387072"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=387073"/>
And here's the tiny step in the front:
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=387075"/>
Hope this helps. If you need more, PM me.
Thank you that's exactly what I needed!!!!!!!!
Old 11-09-2012, 11:23 AM
Originally Posted by Juice Box
The plastic cover of the A pillar is a good place for round rocker switches. Easy access and you can run wires from here to anywhere in or out of the jeep. I used a drill and a dremel, 3 switches look like they're supposed to be there.
There must be a reason why you want switches in your center console... 007?
I used to have the A pillar switch unit but I had to pull it out for the the roll cage. I want it in the center console because I run with out door most of the time and I want the switches protected from crackheads. But 007 sound cooler!
Quick Reply: Out of the country and i need help!
