Optima D34m "blue Top"
WOW
JUST GOT OFF THE PH W/T AND THEY SAY NOT TO USE THE THREADED POST
THEY WILL JUST MELT RIGHT OFF IF USED FOR WINCHING![eek 2](https://www.jk-forum.com/forums/images/smilies/sSc_eek2.gif)
GLAD I CALLED THEM FIRTS B4 I HOOKED THE WINCH TO THOSE
MAW,
Yeah, those threaded posts are for small stuff only. I don't even use them.
You may want to upgrade your battery connectors too, as I did:
![](http://public.mvlan.net/content/Jeep/Evolution/info/640/20080426-150302-lx2-20946.jpg)
If you do, you'll have to change all the connectors on the stock wires too, so it's a bit of a job...
js.
I'm not an optima fan so I'll just say this and leave it be. I bought my first optima over 10 years ago and melted the side terminals. At the time there was no warning anywhere, and the vendor had no idea.
The next one (#2) went dead when sitting, even with all cables unplugged. The third was a trade from a friend, same as #2.
#3 and #4 were brand new delivered with business equipment. Neither lasted a year, but the replacements (not optima) are going strong after 2 more years.
Over 10 years ago there were few options to alleviate the optima "problems". Now there are dozens of great gel cell glass mat batteries on the market. I suspect many of them blow away Optimas for performance and reliability. I know my AGM batteries are far superior to Optimas in every aspect including the ability to use the side posts to full rated capacity.
I'm amazed that they haven't fixed the side post issue yet
![rolling eyes](https://www.jk-forum.com/forums/images/smilies/rolleyes-1.gif)
js.
Almost every other battery manufacturer has warnings about using the side posts for high draw applications - except Optima. Personally I wouldn't use the side posts of ANY battery for high draw applications. There is still a lead to the top post - it's just a matter of how big it is.
As far as AGMs go, I read where their life is dramatically shortened if drawn below 50%, even AGM "Deep Cycle" batteries.
I used to use Optima batteries in my Land Rover Defender 90, but that was mainy because I did not like the idea of having a battery located under my seat that could spew lots of acid on my rear end in an accident.
Good to know about those side posts. I used the for accessories but never thought they were a potential danger.
