opinions on best bang/buck 3.5" lift kit
Currently running a 2.5" RC coil lift and hate the ride apart from the look and function. Looking at a new lift and want a 3.5-4" max lift from stock.
I have a 2012 2door COD with stock drivetrain.
My question is, what is the most complete, best bang for your buck lift kit for $1200 or under. On a strict budget.
I have the control arm drop brackets but would be interested in a kit that included LACs.
Do I need to change the front drive shaft due to the length?
Am I forgetting anything?
Don't mind using stock shocks for now with extensions until I can afford new ones.
Eventually looking to go to 37s, currently running 35s with spacers.
Recommendations, opinions, experience welcomed.
Former Vendor
Typically even at 2.5" lift height you need to be concerned about the driveshaft making contact with the exhaust because of the new exhaust routing on the 2012's. Replacing the front drive shaft is the better option but if money is tight exhaust spacers are always an option.
Now to get to you actual question. Based on your budget I would recommend Rock Krawler's 3.5" Flex System. This kit includes both front and rear lower control arms.
PM us if you want to discuss anything.
