One more tire question
I need some advice from the pros. I have an 08 JK 2 door with a Teraflex leveling kit and then added bilstein 5100s for a 2.5 inch lift. Today I ordered 285/75r17 nitto trail grapplers on 17x9 rims. I'm sure I will clear them on road but is there anything I should / must change before taking it off the road?
Should be good, you may get a small amount of rub at full stuff in the front.
Oh, one thing you can do after you get them mounted use a jack and stuff them and see the clearance. Are you planning on disconnecting?
