Onboard Air Solutions?
#21
MADE IT FOR UNDER $200 INCLUDING FILLING IT. 20#'S OF AIR WILL LAST ME A YEAR OR TWO, RUNS AIR TOOLS AND WILL FILL ABOUT 80 TIRES FROM 0 TO 45 PSI. TAKES 40 SEC TO GET FROM 18 PSI TO 40 PSI. DOWNSIDE IT IS HEAVY AND BULKY, I USUALLY PACK AROUND IT FOR WHEELIN TRIPS OTHERWISE I CARRY A BIG RED PORTABLE FROM PEP BOYS, THAT IS ACTUALLY QUITE GOOD. BECAUSE IT IS A 20# AND NOT A 10# IT DOES NOT LEND ITSELF TO ROLLBAR MOUNTING VERY WELL.
#22
I'm a bit late but here is my setup. I mounted a 2 gal. tank and a Viair 380C compressor on underside of body/frame above rear axle. Made a custom swich/guage panel that houses the relays and pressure switch. Its on at 110psi and off at 150psi. Wiring ran from new fuse panel up front.
Pics attached.
Pics attached.
#24
Pics attached.
Pics attached.
Any problems with the viair and Water mounted in that location?
