OMG! Control Arm drop brackets are AMAZING!
#31
Cam bolts are not suggested anyway. I will not use them on anything no matter what. Drop brackets are still the best for a DD and weekend wheeler (unless you are heavy in the rocks).
For a rough service trail rig and rock crawler adjustable control arms are best.
#32
If I do any off roading it's dirt country roads. Definitely no rocks. So I'm trying to save on tire wear and help the ride. I've got a 14' JKU, 3" BDS suspension lift with JKS adj track bar, running 35" tires.
#33
Ouch!
Well....Yeah! Not much else to say about that. I've only had my Jeep for a couple of years so it's still a learning curve...
Case in point...
Attachment 661111
Attachment 661112
Attachment 661113
Case in point...
Attachment 661111
Attachment 661112
Attachment 661113
#34
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
The stock lower brackets were notched out when the cams were installed, and many people have complained about them slipping over time - especially with offroad use. Better to just remove them if you move to another form of correction. Do a quick search on 'cam bolt eliminator'. It's basically a set of thick washers to install when you remove the cams.
