OME LT shocks. Will sway bar link be long enough?
Hey Guys,
I've got the TF 2.5" coil lift with shock extensions on the Rubi shocks. I just sent Stan at Northridge an email to get a price on the OME LT shocks and extended Crown brake lines. From what I've read the brake lines are probably overkill but I plan to go a bit taller in the future.
My question is that once the LT shocks are installed will my front sway bar links still be long enough in full droop? The front links I have installed are the old rear links that were moved to the front when I installed the lift and new rear links that came with it.
Thanks for your help.
Why wouldn't you be disconnected if you are doing a full droop? I have the TF 2.5" coil lift with TF quick disconnects and the OME LT shocks and have had no problems....Just make sure you have coil spring retainers so you don't loose a spring during full articulation. hope I helped.............
Originally Posted by jdubb75
I'm on the iPhone app and can't see sigs, but I assume the op has a rubi. With the e-disco the swaybar links remain connected to the swaybar. If the end links aren't long enough, the swaybar can be pulled to full vertical at full droop and you run the risk of the swaybar flipping in the wrong direction when the suspension is compressed again. This usually results in an end link that gets twisted like a pretzel.
Hey guys. Sorry I guess I should have thought to mention that I'm running the Rubi with the e-disco. Yeah my main concern is the over extension and "pretzeling" my links. I saw that Northridge offers adjustable links for $80 but if I don't need them I don't want them.
Thanks Planman! I'll just order new adjustable links with the shocks and brake lines. Any recommendations on setting the new links to the appropriate length once installed with the new shocks?
Yeah I got and installed the spring retainers with the TF 2.5 coil lift last year. Oh but I forgot to ask on my last post whether I would need longer bump stops than what came with the TF 2.5 coil lift?
So to summarize my new questions into one post:
1. How will I know what length to set adjustable sway bar links?
2. Do I need longer bump stops?
Cheers guys!
Cheers guys!
I am running a very similar setup and have been fine with the bump stops. I have the jks adjustable disco's and I just set them where both sides slide on and off easily when on level ground.
