OME Lift w/ 37"
I pieced mine together but it would be a lot easier to get the OME Long Travel lift from Northridge4x4. That will give you everything you need suspension wise. Rear control arms would be an added benefit but not definitely needed. Also the performance accessories 1" BL has served me well and was easy to install. Just cut the pinch seam or fold it over, add some flares and use the appropriate amount of bumpstop and you will be good to go. A new front driveshaft might be required
