OME Lift Track Bar Package Questions
Originally Posted by ejfernet
My driving and four wheeling habits are similar to yours. I have had two jeeps, a 2004 LJ with 32"s & a 2011 4 door JK with 35"s. Both had OME springs and shocks which provided a "better than stock" ride and did everything I needed off road. I purchased the long travel OME kit from Dave at Northridge4X4. I changed a few things from the stock kit and he was a great help in figuring it out. I will probably not use the extra travel but as the previous person said it is better to build a little extra capability in. Good luck
Quote from OME:
"Extended length shocks are for 4-6" suspension lifts only and are not intended for uses with any Old Man Emu systems. Modified bump stops are required".
PDF file: http://arbusa.com/uploads/PDF/access...lerJK4door.pdf
Footnote under " old man emu suspension systems".
So...
So...
Originally Posted by Zombie Hunter
Quote from OME:
So...
So...
I have the OME HD and standard shocks. I did not do control arms and the jeep drives fine. I did install track bars and extended bump stops. I also use my jeep more for overland travel than hard core jeeping.
