OME Lift Installed - Need help with Track Bars
On your front JKS adj. track bar, make sure your upper bushing is installed from the rear or it could make contact with the bracket as shown. I called JKS about this and was told it was in backwards and needed to reverse the bushing. And, so far it is working! Just a heads up.
I have font and rear JKS track bars and centered everything up. Just add the rear one and be done.
Which coils did you get? Not pertinent to your problem, just curious based on the amount of actual lift you got. I have a set of standard coils coming and don't want 3" of lift.
