OME lift install this weekend
I'll be installing my NR4X4/OME lift this weekend. Parts have been purchased. Install directions have been cobbled together (largely using WOL's write-ups for the various parts). is in the fridge.
I'll be installing:
OME LD coils (not HD, as I'm only going for 2-2.5")
JKS front trackbar
JKS rear trackbar
Teraflex lower control arms
NR4X4 adjustable rear swaybar links
Teraflex steering stabilizer
JKS rear spring retainers
and JKS quicker discos
I've already got OME shocks (yellow) on the Jeep. Figure this will take me most of the weekend to pull off but am looking forward to seeing the results.
Millions of thanks to dozens of folks on this site for giving me the knowledge I need to even attempt this myself. If I run into snags, you'll all be hearing from me this weekend!
I'll be installing:
JKS front trackbar
JKS rear trackbar
Have fun...I enjoyed putting it on my JKU...first ever lift I put on myself with a little help from my friend. It took me 4.5hrs and it helped greatly to have the computer next to me and review WOL photos and write-up if I got stuck. Also, have a few beer afterwards...very rewarding working on your own Jeep.
I did almost the exact set up around Halloween. I didn't have the jks rear retainers and I added front and rear bumpstops.
It took my Sat and Sun to do the entire lift and WOL alignment by myself. If I had to do it again I would be able to cut the hours down substantially.
The coils were not hard to do as long as you dropped the axles enough (watch the brake lines, I did not have to take mine completely off).
The hardest part was tightening the front adjustable trackbar to the torque spec. Even getting it off was hard. I used my largest crescent wrench as a cheater bar. (You need a large crescent wrench to tighten the adjustment on the teraflex lower control arms).
Setting the length on the lower control arms was kind of a pita. I had the whole jeep back together drove it for a week and decided to readjust the lower control arms.
Be sure to measure everything first before you start. I will really help you in the end when you put it back together. I also used 4 jack stands and a floor jack. It was overkill, but it worked out well for me. The only special tools that I had were an angle meter and a 1/2" torque wrench (if those are special).
With mine HD coils I almost needed a spring compressor but it worked out. Just be sure to have your JK up high enough on jack stands to allow the axle to drop as much as it can. This will make the coils slip in nicely. You can unbolt your shock at the axle, loosen brake lines and it should drop enough for the coil spring.
I installed my OME HD springs last weekend on my JKU. This makes the 6th truck I have installed an OME kit under and have never been disappointed in the results. On my JK I did need to watch any and all electrical wires and brake lines when lowering the axle to get the new springs into place so keep an eye on those. Then as TripleJeep said make sure you get the Jeep pretty high up so you can drop the axle low enough. I probably had about 7-8" of clearance under the tires when I set my jack stands under the frame.
Take your time and don't rush it.
Good Luck
Good Luck
