OME Lift Conplete... now for the sway bar disconnects!
So I installed the OME 2" lift this weekend that turned out to be more of a 3" lift. I want to get a set of quick disconnects for the front and am looking for opinions on which ones to buy. Thoughts?
JKS quicker discos are about the best thing since Reese Peanut butter cups.
http://www.northridge4x4.com/proddet...?prod=JKS-2034
I also need to get new brake lines. I was looking at the stainless steel ones, but also see there is just a stupid spacer that costs like $9 and just lowers the mounting spot. I don't want to half a$$ this thing, but also dont want to throw away money. Are the new lines needed or just get the bracket?
Those are the ones I was looking at. How often do you need to grease them?
I would suggest getting the new brake lines for a 3"+ lift.
The rear brake lines should be replaced when you do the front. If you're talking about the sway bar links you could get something like theis. http://www.northridge4x4.com/proddet...od=CLY-2308101
