OME Lift and 2" JKS Quicker Disconnects
I'm using the 0"-2" JKS quicker disconnects with the Teraflex leveling kit. Can I reuse these with the OME 2" HD lift kit, or will I need the get the ones designed for 2 1/2"-6" lift?
i got the 2.5-6 for mine, i have to have them turned out one thread for a good level. I'm assuming the 2.5 at the very least will be longer than the 2 inch max, and i think you def need it for the ome (i have the same kit, standard springs for a 4d)
For the HD OME's I think you'd be happier w/ the longer QD's. You should be able to sell your original ones pretty easily. At least I hope so, since I'll be doing it in a couple weeks.
