Ome hd lift + tf leveling pucks?
Hey guys. I'm having an one hd lift with lt shocks, bumpstops, brake lines, adjustable track bars. No control arms at this point. I want to run my current tf leveling pucks on top of the ome lift as the rear is a spring retainer as well.
What is your guys opinion on this? Should I run both front pucks or just one? Is here any rake remaining with the ome springs?
A spacer on top of new coils isn't a problem --> if you are set up for the height!!
You will be over 3" with the OME HD's. Add spacers on top, and PLAN on adding control arms.
You have two sets of front spacers now? Or you only want to run them on one side?
I'd add in some adj front lower control arms. Adding those pucks will most likely put you in the new drive shaft department.
Yea my leveling kit came with (2) 1 inch spacers for the front and (1) 1 inch spacer for the rear.
I want to run the rear spacer as it also functions like a spring retainer during heavy articulation.
And yes, in going to 37's in the spring. I have a set of almost new toyo mt's in my barn. 37x14.5x15.
I've got flat fenders as well. I really just wanted to use the pucks as a rear coil retainer. I'll be adding front lca's when the money comes in regardless of pucks or not.
Edit: I have no problem using only one 1 inch puck front and rear to avoid being nose up.
http://northridge4x4.com/proddetail....K-LIFT&cat=272
With this OME HD lift and flat fenders, you should be able to run 37's.
Also, what is the length of the new brake lines? I ordered the 'extended' crowns from Northridge with my ome hd lift, and ripped a rear line off the frame. Went to the hardware store and made extension brackets in addition to the extended lines...
You should also consider adding extended bumpstops, especially if you will you be disconnecting. The fronts go 'inside' the coils, so add them during the install. Rears can be added any time. (with 32" actual height tires and stock bumpstops, I was rubbing the front fenders hard enough to rip them off...)
David
I have thought of adding front spacers as well. After a year of an aftermarket bumper and winch, the front has sagged about an inch. I am just a little concerned if I add a small spacer to the front, then it will be nose up.....so we shall see.
I added front upper and lower TF adj. arms. Major improvement in steering / handling.
Hope the money comes in soon. 4.25" on stock arms will make for a very fun ride.
