ome coils on jku? ????
Old 01-03-2012 | 09:31 PM
arasco85's Avatar
Default ome coils on jku? ????
What coils do you have on your JKU. Im trying to figure out also if there is a difference in the 2 door and 4 door coils? Or are the coils only based off of ratings?
Old 01-04-2012 | 04:35 AM
OverlandJKU's Avatar
Coils are based on load... I have the hd coils on my JKU...with winch, bumpers, etc they are just right.....
Old 01-04-2012 | 05:18 AM
I went with OME shocks, trackbars, front lower and rear upper Teraflex arms, longer sway bar links and a front driveshaft. I need bump stops, which I didn't expect.. I was amazed at the amount of flex with this kit. The write up on project jk and buying parts from northridge made the install a breeze....
Old 01-04-2012 | 05:27 AM
arasco85's Avatar
What are the hd coils? 618-620?
Old 01-04-2012 | 02:45 PM
arasco85's Avatar
thanks for all the great info.
Old 01-04-2012 | 03:01 PM
Rainier's Avatar
The coils are the same for the 2dr and 4dr. The coil rating will determine how much lift you get. I run the HD coils 618's/619's on my 4dr. If you did the same on a 2dr you would net more lift than what I got, which is about 3"
Old 01-05-2012 | 07:10 PM
arasco85's Avatar
Thanks man. That's all I was asking lol
