OME +40 Lift
OME +40 Lift
What is the measurement for me to set my Rear LCA's for a OME+40 coil lift on a 4 door?? Anything close would be a good starting point They are Clayton arms. thanks Steve
I'm interested in this too..
based on this:
I guess you'd start around the length of the TF 3" lift (?)
when are you putting yours on?
I assume David & Eddie will chime in with some solid advice.
(I'll be adding TF rear lowers & uppers + need to adjust front lowers)
based on this:
after running these new coils for about 3 months, we're still seeing about 4" of lift. over the weekend, we parked our JK side by side with another 4-door JK that has a TF 3" lift (actual height is about 4") and 35" tires and our JK sat at about the same height if not a tad higher.
