OME 2" Suspension?
Old 11-25-2009 | 09:27 PM
RevyJKU08's Avatar
Originally Posted by cojk
Best I have for a side shot
.Any rubbing at full flex?
Old 11-25-2009 | 09:30 PM
cojk's Avatar
Yes, they are 35x12.50 17's. Had some minor rubbing at full flex but nothing too bad. Thought about adding some bumps stops but not bad enough rubbing to get worked up about.
Old 11-25-2009 | 09:31 PM
RevyJKU08's Avatar
Good to know...thanks for the information!
Old 11-25-2009 | 10:00 PM
nthinuf's Avatar
You have disconnects. He does not. Makes a huge difference. Make sure you are comparing apples to apples.
Disconnected, you will rub...
This is with 2" lower bumpstops and 295/75/16's (32" actual height on vehicle), and I'm still rubbing. You're 35's will be about an inch taller, and an inch wider. Do the math...
And here is the coil without bumpstops
Old 11-26-2009 | 07:12 AM
jeepmedic's Avatar
You shouldn't need any thing extra. I didn't ! I also ended up with almost 3.75" lift.
Old 11-26-2009 | 07:27 AM
RevyJKU08's Avatar
I guess if the rubbing is too much...I could add on a 1" to 1.5" spacers along with the coils or 1" BL. Are these HD coils the same length as the TF 2.5" coils springs?
Old 11-26-2009 | 07:34 AM
Outdoors's Avatar
Thumbs up
ahhh... Apples to Apples, so true...
I rub with my 285/ 32.8's.. whatever..
Now I have stock off set wheels, not good.. remedy
get wheels or spacers...
Still rubbing...? Get bumpstops 2.5' rear and I hear a 1" front works well confirmation on the last part is needed..
Still rubbing..?
Then get back to us where it's rubbing.
For me I'm cutting out my flares when I go 35's.
Old 11-26-2009 | 07:52 AM
G16's Avatar
G16
Originally Posted by Bcasey
Ok I know I am an FNG when it comes to Jeeps but I need to ask. If I go with the "OME 2" HD suspension system" will I need to add or replace anything else? It is sold with coils, shocks and a track bar bracket. My offroading will be modrate trails no rock crawling.
This thread might have some helpful information.
https://www.jk-forum.com/forums/modified-jk-tech-2/my-first-lift-2inch-ome-terafex-km2-lt-285-70-r17-41633/
Old 11-26-2009 | 10:07 AM
river2c's Avatar
I have plenty of clearance for 35's with no rubbing at all - even when disconnected at full stuff and with aftermarket bumpers. I used the extended bump stops and extended brake line brackets from the TF BB kit. However, the OME lift will be slightly less with an Unlimited.
Old 11-28-2009 | 09:36 PM
sly's Avatar
sly
sine i just put my OME lift on this is what i can tell you.
you will need spacers 1.5 inch and on my unlimited i will have to trim some metal of the oem slider and that pinched seem at the bottom
good luck
