OME 2" Suspension?
You have disconnects. He does not. Makes a huge difference. Make sure you are comparing apples to apples.
Disconnected, you will rub...
This is with 2" lower bumpstops and 295/75/16's (32" actual height on vehicle), and I'm still rubbing. You're 35's will be about an inch taller, and an inch wider. Do the math...
And here is the coil without bumpstops
ahhh... Apples to Apples, so true...
I rub with my 285/ 32.8's.. whatever..
Now I have stock off set wheels, not good.. remedy
get wheels or spacers...
Still rubbing...? Get bumpstops 2.5' rear and I hear a 1" front works well confirmation on the last part is needed..
Still rubbing..?
Then get back to us where it's rubbing.
For me I'm cutting out my flares when I go 35's.
Still rubbing..?
This thread might have some helpful information.
https://www.jk-forum.com/forums/modified-jk-tech-2/my-first-lift-2inch-ome-terafex-km2-lt-285-70-r17-41633/
I have plenty of clearance for 35's with no rubbing at all - even when disconnected at full stuff and with aftermarket bumpers. I used the extended bump stops and extended brake line brackets from the TF BB kit. However, the OME lift will be slightly less with an Unlimited.
sine i just put my OME lift on this is what i can tell you.
you will need spacers 1.5 inch and on my unlimited i will have to trim some metal of the oem slider and that pinched seem at the bottom
good luck
good luck
