OME 2" Lift on 2012 JK
I am about to order my lift with track bars and need to know if I will need anything else? Driveshaft? Exhaust? I have read many post with 3" lift needing these things and have heard the OME lift can be 2.5" - 3" of actual lift. If anybody has experience and can share some info it would be greatly appreciated. Thanks!
If i've researched correctly....OME 2" lift is closer to 3", especially withe the HD coils.
At 3" you'll need the get the exhaust spacers to clear the driveshaft, or an aftermarket driveshaft.
See also: https://www.jk-forum.com/forums/show...our-lifted-JK!
I'm not sure if you need brake line relocation brackets with that kit, and you haven't specified if youre running extended shocks or not,....for shock extensions.
Originally Posted by Chrislh
Will putting on HD raise me too high to where I'll need new drive shaft
