Old Man Emu 4inch?
Old 06-19-2012, 05:06 AM
  #41
chaz14_9's Avatar
Originally Posted by aldaman
This kit looks very promising and is on top of my wish list when I eventually pull the trigger to lift my JK. I am still debating whether to go w/OME, TF or RK. If I do choose this lift I will be installing TF front adj LCAs (have them still in the box). Does anyone have the installation instructions for this kit? if so can you post it or PM it to me. Thanks...
I tried searching for the instruction online but couldnt find any...
Yeah I have them on my work computer. I can email them to you.
Old 06-19-2012, 07:04 AM
  #42
CCGRUNT0331's Avatar
Got a question about the older 3" OME HD, bought at Northridge so it has teraflex LCAs and whatever else Dave's experience has led him to put on, Im running 35s but at highway speeds it wanders a bit, nothing major but I noticed no front stabilizer. Would that help or is it designed for a hi steer kit? Also, slightly too stiff for my pot-holed town, would it be wise to change shocks or are coils the cause? Sorry to hijack this thread but I saw some experts commenting.
Thanks for any help or suggestions
Old 06-19-2012, 08:36 AM
  #43
Sponsoring Vendor
Northridge4x4's Avatar
Check your castor if it is wandering. Should be approx 4.5 positive.
Too stiff and OME are rarely ever used. Normally the complaint is the OME is to soft , responds to slowly.
Old 06-19-2012, 08:48 AM
  #44
Thanks Ill check it out after work, I have the HD version without full replacement bumpers so maybe Im too light but could you recommend bilsteins or an upgraded rancho shocks or are the stiffer coils the culprit? I understand a straight axle jeep on 35s will bounce but my lower back has been suffering
Old 06-19-2012, 08:50 AM
  #45
Sponsoring Vendor
The Hd springs are very close to the same spring rate as the standard coils just the HD coils are taller.
If you want to change shocks I would suggest Bilsteins.
David
Old 06-19-2012, 09:06 AM
  #46
Thanks i appreciate the help!
Old 06-19-2012, 04:27 PM
  #47
ksuferrara's Avatar
Mind sending me a copy too?
Also, i'm assuming with my 2door i will need a new rear drive shaft?
Old 06-19-2012, 04:29 PM
  #48
chaz14_9's Avatar
Sure pm me your email and I will send it tomorrow
Old 06-20-2012, 04:11 PM
  #49
aldaman's Avatar
Thanks for emailing the installation instructions....
Old 06-20-2012, 04:14 PM
  #50
chaz14_9's Avatar
No problem hope it helps the decision
Quick Reply: Old Man Emu 4inch?
