Old Man Emu 4inch?
#41
Originally Posted by aldaman
This kit looks very promising and is on top of my wish list when I eventually pull the trigger to lift my JK. I am still debating whether to go w/OME, TF or RK. If I do choose this lift I will be installing TF front adj LCAs (have them still in the box). Does anyone have the installation instructions for this kit? if so can you post it or PM it to me. Thanks...
I tried searching for the instruction online but couldnt find any...
#42
Got a question about the older 3" OME HD, bought at Northridge so it has teraflex LCAs and whatever else Dave's experience has led him to put on, Im running 35s but at highway speeds it wanders a bit, nothing major but I noticed no front stabilizer. Would that help or is it designed for a hi steer kit? Also, slightly too stiff for my pot-holed town, would it be wise to change shocks or are coils the cause? Sorry to hijack this thread but I saw some experts commenting.
Thanks for any help or suggestions
#43
Too stiff and OME are rarely ever used. Normally the complaint is the OME is to soft , responds to slowly.
#44
Thanks Ill check it out after work, I have the HD version without full replacement bumpers so maybe Im too light but could you recommend bilsteins or an upgraded rancho shocks or are the stiffer coils the culprit? I understand a straight axle jeep on 35s will bounce but my lower back has been suffering
#48
Originally Posted by ksuferrara
Mind sending me a copy too?
Also, i'm assuming with my 2door i will need a new rear drive shaft?
