Oil pan tranny skids that work with exhaust extensions
http://project-jk.com/gallery2/main...._itemId=268505
You can use the engine and trans skid plate with no problem. Its the crossmember skid plate you can't use because of your spacers. You can purchase the skids separately. This is a pic of the trans skid. Its on top of the exhasut crossover and not going to contact the driveshaft
IAN April 25th, 2012 3:26 pm
Does not work with teraflex exhaust spacers. Not enough clearance on the crossover pipe. FYI, bought a new driveshaft and removed the spacers. All good now
". . . The oil pan skid can be used separately but the transmission pan skid must be used with the entire system."
I run the Rock Hard skids on my 2012 and I have TF spacers. No problem at all! I put the 1/4 inch spacer in the back just for a little extra room at the crossmember. They are nicely finished and work great.
When you say in between the "pan" and cross frame are you referring to the Off Road Evolution Exhaust skid or the Tranny Skid or some other "pan"?
