Oil filter alternatives
#31
I've had two PureOne filters give me the startup knock. The first time I figured it was a just fluke, so I tried another one. Now using a Mopar filter, and the knock is gone. If I were a betting man, I'd bet that the PureOne and the Mobile 1 filter use the same ADB valve, and that they both source it from somewhere in China. Poor quality control. There might be good ones out there, but I struck out twice. Never again.
#32
JeepSWAG
Sponsoring Manufacturer
Hate to do this to my beloved Amsoil, but I have the clatter with one of their filters. I'm going to change it out, to see if it will go away.
#33
#34
I don't understand this discussion. I've always come from an, "If it works don't fix it," standpoint and this just doesn't make sense. Mopar designed the 3.8 and developed the corresponding filter. Of all the things I change around on a vehicle, I never go with anything other than OEM oil filters. Why would you want to go with anything other? As long as you do the regular 2500-3000 mile changes these should be good as gold.
#35
JeepSWAG
I don't think this is a fixed or broken question. If you have a better filter (knowing fully, that "better" is a rhetorical question), then your engine will last longer.
#36
BTW, love that stabilizer bracket. Gonna test it this weekend in the Pike National Forest.
#37
Based on some testing data, the Mobile filters appeared to have a reputation for filtering better than most, unfortunately since I have the clatter I'm going back to the stock filter and see if that fixes the issue. It is a mod just like anything else we do to try to improve performance in some fashion, IMO.
#38
Uhhhh....how can a bumper be better than OEM? How can rock rails be better than OEM? How can skid plates be better than OEM? How can wheels and tires be better than OEM? Suspension? etc etc etc...........
These are Jeeps, man. We are tinkerers. Just because something came from the factory doesn't mean it's the best option available.
#39
Motorcraft filters are by ALL means very average filters. Ford just pays a few manufacturers to make the filters for them. Same with the oil, its just valvoline. The motorcraft filters and oil are nothing special at all. If you guys really want to upgrade the oil filter and oil, your best best bet is to go with AMS Oil and AMS Oil filter.
#40
*UPDATE*
I changed out my Mobile 1 filter yesterday back to a Mopar unit, no more clatter! In fact, when I pulled the Mobile filter, barely a drop of oil came out, it is definitely a check valve issues. Any time I've pulled the Mopar filter oil spills out. No more Mobile 1 filters for me!
