Off Roading
Old 08-12-2013 | 10:39 AM
Jdrage5's Avatar
Default Off Roading
Ok. Excluding, tires and a lift what are the off road mods that are needed for a 2013 wrangler?
Old 08-12-2013 | 10:43 AM
kh202's Avatar
Depending on what kinda trails you're looking to do, nothing is needed. You'll be amazed at what your stock jeep can do. But as for other mods, they are directly related to what size tire you want to run.
I recommend go wheel it stock and see how it performs, then go from there.
Old 08-12-2013 | 10:46 AM
jfresh360's Avatar
Cant go wrong with a good set of recovery tools. D-rings shackles shovel straps etc.
Old 08-12-2013 | 10:49 AM
jk.bushwacker's Avatar
X2 maybe add a winch too
Old 08-12-2013 | 10:51 AM
brighton's Avatar
As mentioned, terrain makes a big difference. If you play in rocks, armor such as rock rails and skid plates. If you like water crossings, extending breather hoses or maybe a snorkel.
Old 08-12-2013 | 10:52 AM
Smashboogie 4x4's Avatar
Former Vendor
As KH202 mentioned get out there and wheel it stock. Once you get out there a few times then you can decide what you need. This will also help you become a better driver and pick a better line as you build up your rig a bit more.
Old 08-12-2013 | 10:53 AM
Jdrage5's Avatar
I was think more about mods to the under body
Old 08-12-2013 | 10:55 AM
kh202's Avatar
Wheeling a stock JK also gives you a sense of how much it dominates any other vehicle right out of the box! If you're new to wheeling, but sure to go with someone who has some experience and can take you on appropriate trails
maybe a evap skid and an engine or oil pan skid. dif covers. plenty of good stock protection under there already. not much needed IMO
Old 08-12-2013 | 10:58 AM
kh202's Avatar
I agree. You are pretty protected as is. My stock skids and under side are beat to hell, but the oil pan and evap were never touched.
