Off road olny third brake light
Just bought the third brake light with license plate light but I can't figure out how to wire the thing up I tried going through the old third brake light harness through the tailgate but it won't light up I'm not the best at wiring but can anyone help a fellow jeeper out!?
If you have this one...
![Click image for larger version
ID: 601976](https://www.jk-forum.com/forums/attachment.php?attachmentid=601976&thumb=1&d=1513724301)
with the brake light and license plate light, then you need 3 wires and the factory brake light harness only has 2 wires. You can fish another wire through the factory sleeve in the tailgate - just use a small (18 or 16 gauge) wire. I actually added a backup light (6" LED bar) to mine at the same time, so I had to add 2 more wires. I can send more info and pics if you need more help.
Former Vendor
The ORO Light should have very good wiring instructions with it. As mentioned in the post above you need 3 wires. We put one of the wires into the right brake light and the other two go to the factory 3rd brake light harness.
If you have this one... <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=601976"/> with the brake light and license plate light, then you need 3 wires and the factory brake light harness only has 2 wires. You can fish another wire through the factory sleeve in the tailgate - just use a small (18 or 16 gauge) wire. I actually added a backup light (6" LED bar) to mine at the same time, so I had to add 2 more wires. I can send more info and pics if you need more help. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=601982"/>
I don't mean to go back on my offer to help, but I just did a quick search and found 2 separate write-ups for this install and both have the wire color code included. This will be faster than me writing up the entire install. I would be happy to answer any specific questions you might have though. If you send me a PM, I'll send you my number and we can talk or text.
https://www.jk-forum.com/forums/jk-w...elite-29385/#b
https://www.jk-forum.com/forums/jk-w...umper-90672/#b
I don't mean to go back on my offer to help, but I just did a quick search and found 2 separate write-ups for this install and both have the wire color code included. This will be faster than me writing up the entire install. I would be happy to answer any specific questions you might have though. If you send me a PM, I'll send you my number and we can talk or text. https://www.jk-forum.com/forums/jk-w...elite-29385/#b https://www.jk-forum.com/forums/jk-w...umper-90672/#b
This is the color code for the factory wiring in the taillight and the ORO colors:
White with yellow line - Brake light - (ORO) Red
White with purple line - Parking lights with license plate light - (ORO) Green
White with tan line - Ground - (ORO) Black
