odometer off by how much???
#51
according to the calculator on 1010tires.com the speedometer difference between the 255/75R17 (32") my Jeep is programmed for, and the 35x12.50R18s spinning under it is 8.475% too slow
It claims that at 60 mph actual my speedometer says 55.3mph.
#53
just wanted to make sure that i got this
bigger tires and same gears means spedo will read slower than you are going
bigger tires,say 35s and taller gears like 5:13s,depending on the size of the tires that you get will make the spedo read a little bit faster than you are going
so when you upgrade both tires and gears the same time you should be close to the original speed on your spedo,give or take a little
my head hurts,o well
#54
#55
Quadratec sells new speedometer gears look under speedo gears they have a chart in the catalog but i cant find it on their website. I am going to be in the same boat going to 40's soon
thanks
Mike
thanks
Mike
#56
