odd wobble at 60
odd wobble at 60
Okay i know its not death wobble, or a loose track bar, or a balance issue, Ive checked all of them...many times.
I have an odd wobble from 60-65MPH. I checked over everything had my buddy (jeep mechanic) check over everything adn we cant figure out why it is doing this. I recently replaced the front unit bearing everything torqued back to spec. any suggestions to what might be the cause...and yes i have a bigger stabilizer.
any ideas are greatly appreciated.
thanks
more info. 2.5 coil spring lift no spacers, JKS sway bar discos, stock 33" tire nothing fancy.
thanks
It might help if you listed you lift height, if any, type and size tires, and any other mods you may have.
Generally speaking speed related wobble or shimmy is usually tire related.
