Odd brake issue... need help
Ok
So after I installed my lift and 35"s I noticed that when i go around a corner with the clutch engaged that if i break I feel a shuttering in the brake peddle and hear a noise.
It almost seems like the ABS is mis-engaging...
Ideas? I am totally clueless on this one.
Is your steering wheel straight?
i had the same problem. I did my alignment (I am an ase certified master tech) and use my aev pro-cal to center the steering wheel, but when I went down this one road and hit a bump while going through a turn, I had the same issue. I did my steering calibration again and have not had any problems since.
