Observations after 2" Teraflex Leveling Kit and Rough Coutry Stubby Bumper Mod
Old 08-22-2013 | 12:10 PM
groovebus's Avatar
Default Observations after 2" Teraflex Leveling Kit and Rough Coutry Stubby Bumper Mod
Lift - I did the entire thing top to bottom in 4 hours by myself
1. Make sure to use spring compressors. (makes the job alot easier)
2. After the lift is installed, re-torque all control arm and track bar bolts.
3. There isn't any indexing on the rear springs to mark where the springs should be sitting when you put them back on. The pig tail end of the springs should be on the rear facing side of the axle. Make note of where they are when you start (if you don't, they will bulge. Had to take the right rear tire apart again to fix it.)
4. You have to press the rear spacer into place. I used the bumpstop, 6" wood block and the jack to press it in.
Bumper mod - 30 minutes
just follow the directions and use a new sawzall blade.
ID:	490638   Click image for larger version
ID:	490639   Click image for larger version
ID:	490640   Click image for larger version
ID:	490641   Click image for larger version
