OBA remote connection front and rear
MV-50 is installed in the engine bay (using a Sinister Fab bracket) and I would like to install a QR chuck at the front frame rail and possibly at the rears well.
I haven't installed a tank, though probably will some time in the future... For now, it's a run from the compressor to a manifold to split it and then out to the front and back.
I am looking for install suggestion and some tips on making it reliable and easy.
Really appreciate that!
If you have any install suggestions I would be thankful if you could share.
I've read of the melt-down of a few aftermarket hoses installed at the compressor so I am curious what should be used to connect between the compressor and the manifold. I've seen copper tubing with compression fittings used, as well as silicone hose.
